DIYnot
Local | Network
   DIYnot > Forums
Local | Network
inadequate ventilation in loft
This topic originated from the How to page called Loft Insulation
Click here to return to the page called Loft Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
BJW
from United Kingdom
PostPosted: Wed Dec 14, 2005 7:50 pm Reply with quote
having been in my house two months I have discovered condensation on the north side of the pitched roof which is soaking into the joists.... I have removed the insulation which was blocking the gaps to the soffits, although I cannot see any obvious vents in the soffit board area. I hope this will help. Do i need to do anything else?
Back to top
 Alert Moderators
Johnboy54
from United Kingdom
Thanked: 2 times
PostPosted: Thu Dec 15, 2005 12:25 am Reply with quote
Your soffit boards should not be flush with the wall.
Do you mean they are?
The vent is the gap between the wall and the soffit board.
The new-type plastic vents you see are just to stop the birds and bees being naughty in your loft.
You've done the right thing by removing the insulation that was blocking the airflow.
New builds have a currogated plastic sheet in that area over the insulation to ensure a gap.
North facing is the coldest direction, so without ventilation it's not surprising you've got condensation at this time of year.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Will I be left with inadequate support? 5 180 Sun Jan 26, 2014 9:36 pm
Inadequate Crawlspace 9 260 Wed Mar 11, 2015 6:49 pm
Dangerous discovery? Inadequate support for floor? 13 360 Tue Feb 24, 2015 1:12 pm
Heat Recovery Ventilation - Loft Input? 6 660 Thu Feb 09, 2012 8:17 am
Advice regarding Cellar treatment and ventilation 10 380 Thu Aug 18, 2011 1:49 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
