Having problems with our combi boiler and thought somebody may be able to advise what the problem is.
We have an Alpha CB24/28 (I'm just reading this off the front of manual so if its a choice of a 24 or a 28 not sure which one)Anyway the central heating seems to be fine but the hot water takes ages to come through and even on the highest setting is not v hot. I have tried resetting the system but this hasn't helped and also turned the switch from CH&HW to HW only. When I did this I didn't get any hot water at all.
All the ignition lights seem to be functioning as they should in the manual as have gone through the fault finder section and this seemed fine.
Any ideas what the problem could be - let me know if you need any more info.
Many Thanks
Many Thanks
