DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hot Dimmer Switch
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
uptight
from United States of America
Thanked: 0 times
PostPosted: Thu Dec 15, 2005 9:59 pm    Post Subject:
Hot Dimmer Switch
Reply with quote Thanks
The metal plate on my lutron dimmer switch is very hot to the touch when the switch is on. What might the problem be?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 15, 2005 10:03 pm    Post Subject:
Re: Hot Dimmer Switch
1: do you have it on low? could just be heat from making the light dimmer. how hot is hot?
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 16 times
PostPosted: Thu Dec 15, 2005 11:16 pm    Post Subject:
i'd guess the dimmer is either underrated or faulty, domestic dimmers should not get hot.
Back to top
 Alert Moderators
uptight
Thanked: 0 times
PostPosted: Wed Dec 21, 2005 5:33 pm    Post Subject:
I've found the culprit!
I’ve determined that the combined wattage of the halogen recessed lights connected to the switch is greater than that of the switch itself. Therefore causing it to work too hard and ultimately get hot. Solution will be to either switch to lower wattage bulbs or replace the switch with one that has a higher wattage capacity.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
How to rewire a slide-type dimmer switch (France) 5 980 Fri Feb 11, 2005 4:20 pm
1Way Dimmer to a 1 way switch, weird black plastic box 6 860 Thu Nov 09, 2006 9:12 pm
Looking for a certain dimmer switch 3 1760 Mon Sep 25, 2006 4:49 pm
dimmer switch help 19 1640 Wed Nov 30, 2005 6:24 am
replacing a double switch with a single dimmer 3 1040 Wed Feb 02, 2005 10:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
