DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
t joint leak
This topic originated from the How to page called Repairing a burst pipe
Click here to return to the page called Repairing a burst pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
tablet nurse
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 16, 2005 12:55 pm    Post Subject:
t joint leak
Reply with quote Thanks
tried for 2 hours....water off ..pipe dry ..sweated off elbow of 15x15x15 T joint..cut replacement part..fluxed it ..inserted it ..would not solder..again/again/again..kept leaking..soldered loads before no problems..my brother was on about oxidization? icon_confused.gif icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Dec 16, 2005 1:57 pm    Post Subject:
Re: t joint leak
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 16, 2005 3:06 pm    Post Subject:
probably wrong flux or water still in pipe why not replace with compression joint
Back to top
 Alert Moderators
tablet nurse
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 18, 2005 1:05 pm    Post Subject:
pipe leak
unable to use compression joint due to space.will try new flux
many thanx
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sun Dec 18, 2005 5:05 pm    Post Subject:
Re: pipe leak
many thanx
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
fixing small leak on solder joint 4 1800 Mon Jan 22, 2007 11:43 am
Boiler Heating joint leak 9 600 Thu Oct 20, 2005 8:33 pm
Shower joint leak/exposed valve 6 560 Tue May 09, 2006 3:11 pm
compression joint leak 18 4780 Sat Mar 31, 2007 12:13 pm
Slight leak from compression joint - fix options? 11 1620 Fri Jan 07, 2005 1:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
