DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
hot water cistern
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jaki
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 17, 2005 8:19 am    Post Subject:
hot water cistern
Reply with quote Thanks
I have recently removed a radiator from the kitchen. since then I have had no hot water, however my central heating works well. pump is ok. thermostat working. can anyone help. thanks
the system is a gravity fed system. ? closed loop, what ever that means.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Sat Dec 17, 2005 8:35 am    Post Subject:
We are well known for our mind reading capabilities. Unfortunately it doesn't work in Durham (maybe the hills or something). Can you post details of your system?
__________________
Let's face FAQs.
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 17, 2005 6:56 pm    Post Subject:
Check c/htg header tank is full of water ballcock not stuck etc or suspect blockage in cold feed or snapped gate valve etc.etc.etc
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Water supply connection actually in toiley cistern 4 160 Thu Sep 18, 2008 7:45 pm
overflowing hot water cistern 17 400 Thu Jun 05, 2008 8:15 pm
Cold Water Cistern in Attic is overflowing 13 740 Sun Apr 26, 2009 11:37 am
Connecting water supply to a 15mm plastic thread on cistern. 3 380 Thu May 18, 2006 6:57 am
Cold water cistern overflow mystery... 6 400 Wed Sep 29, 2004 10:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
