frances
Joined: 20 Oct 2003 Posts: 2 Location: United States of America Thanked: 0 times
Posted: Mon Oct 20, 2003 12:22 am Post Subject: red painted walls |
I primed the walls and then painted them red (2 coats) and they are still not right they are darker in some places then others, you can still see some of the roll marks, what do you suggest. I was thinking maybe lightly sanding the areas that have to much paint and then paint them one more time. Thanks for your help |
masona
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Mon Oct 20, 2003 1:17 am Post Subject: |
Make sure you have stir the paint plenty of time before using and if you're using more than 1 tin of paint,best to stir it altogether in a bigger tin.You might need a couple more coats to get the same colour as it should eventfully even out unless the paint is faulty.You don't say if it's for internal or external wall and what sort of paint it is etc...........
The roll marks is usually too much paint on the roller or squashing it too hard on the walls. |
frances
Posted: Fri Oct 24, 2003 12:06 am Post Subject: |
Thanks for your help, the paint is interior (livingroom walls) and its a satin finish. |
AlanB
Joined: 15 Jan 2004 Posts: 1 Location: United States of America Thanked: 0 times
Posted: Thu Jan 15, 2004 9:52 pm Post Subject: Interior Painting with Red |
Hey Frances -
I am in the same boat as you ..have done 2 coats now using eggshell finish...wondering how you get on as i'm at the point of just going back to the original boring as i'm extremely frustrated..
also can you tell me how you did the edges...as that's been another problem area.....did u end up using a regular roller for the next coat
thanks
Alan |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Thu Jan 15, 2004 9:57 pm Post Subject: |
sorry AlanB  it is unlikely frances will reply since he posted in October 2003, and his posting total is 2 (look under his name) and both posts are there for you to see.
May i suggest that you start a new topic in the decorating forum which you can get to by clicking here __________________ Do you like music Mr Finch?
Forum = Opinions |
