muks
Joined: 23 Dec 2005 Posts: 2 Location: London, United Kingdom Thanked: 0 times
Posted: Fri Dec 23, 2005 4:12 pm Post Subject: moving the position of my radiator |
hi every1 i need some help plz
im currently fixing my younger brothers room but the radiator is currently in a very bad position and i wish to move it down the wall a bit so that he can use the space to its fulest.
so what i was wondering is how can i do this. can some1 tell me steps to take to complete this task plz.
like wat tools will i need?
wat i should do?
any help will be greatful
thank  |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri Dec 23, 2005 6:38 pm Post Subject: |
I am sure you will get some help on this site, but if you are starting as a complete novice, you might do well to get a DIY book (out of the library perhaps) which will talk you through it with plenty of illustrations and explain how things work. There are plenty about. No offence meant. If you get stuck, or something is not clear, ask again. |
Soggy_weetabix
Joined: 20 Dec 2005 Posts: 1639 Location: Bedfordshire, United Kingdom Thanked: 0 times
Posted: Fri Dec 23, 2005 7:03 pm Post Subject: |
Two usefull tools...
A 'basic understanding' of what you are doing. Plumbers are tradesmen after all.
'Common sense' to tackle any problems you come across.
You will need, basically...
Adjustable spanner (s)
Pipe cutters
Jointing compound
Drill
Level
Screwdrivers
Fixings suitable for the wall
Hose, or freezer kit, or easy drain kit.
Bleed key
PTFE (if new rad)
New pipe and soldering equipment if required
Suitable dust sheets
A type of paper to check for dry joints. (you are a DIY-er after all)
Drain system (or freeze / bung)...remove rad and re-pipe to new position, refill system vent & test.
If you dont understand this, get in a tradsman who does |
muks
Posted: Sun Dec 25, 2005 4:39 pm Post Subject: |
emm ok, well thanks alot for the info.
im not going to carry on with this project because its above my level. im going to get a professional in to do it.
thanks again
p.s. how much do u fink it will cost to get a professional to do it???? |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
