Joined: 23 Dec 2005 Posts: 10 Location: Leicester, United Kingdom Thanked: 0 times
Posted: Fri Dec 23, 2005 9:56 pm Post Subject:
Hallway Light Switch
hi and merry xmas..
Just a quick basic one...
ok i was about to remove my downstairs hallway light switch to redecorate. When doing so i noticed that 4 of the wires had fallen out..suppose whoever installed it forgot to tighten the screws.
2 x red and 2 x black have fallen out of the double light switch. the spaces that they fell out of are L1 & L2(two sets of spaces)
i have tried putting them back in as i thought but i ended up controlling the kitchen and living room.. lol
is it as simple as red goes in ... and black goes in.....
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Fri Dec 23, 2005 10:58 pm Post Subject:
do you have 2 way switching? id guess that each T&E feeds 1 light, so try the red and black from 1 T&E into L1 and L2 in 1 half of the switch, and the other T&E for the other half. does this work?
also, you say that it controls the kitchin and living room light. are they different rooms with completly different switches?
also, the earths must be connected if your using a class 1 switch, otherwise they should be in the terminal block on the backbox or a terminal block. but if you ever do need them and there long enough, make sure that they are connected at the other end aswell
Posted: Fri Dec 23, 2005 11:05 pm Post Subject:
i have tried that.. i havent crossed them over at all.. this is when i get the kitchen and lounge doing funny things
Posted: Fri Dec 23, 2005 11:19 pm Post Subject:
try puttin 1 red in L1, another red in the other L1, and connect both blacks together, but not in any terminal on the light switch
Posted: Fri Dec 23, 2005 11:28 pm Post Subject:
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
