Not worked on these boilers much can hear div valve motor working, also when it does it sounds noisy, when running hw only the ch flow pipe gets hot, close of the ch flow on its isolator the burner modulates lower and the dhe stays cold on both entry exit, hot water temp still poor.
I think the div valve is stuck on ch but may also have blocked dhe, do the div valves go on these boilers regular, looks like a difficult to change them.
Any ideas or shall i buy div valve + dhe to be sure ?
