In the regs it states:
522.6.6
(v) be installed in a zone within 150 mm from the top of the wall or partition or within 150 mm of an angle formed by two adjoining walls or partitions. Where the cable is connected to a point, accessory or switchgear on any surface of the wall or partition, the cable may be installed in a zone either horizontally or vertically, to the point, accessory or switchgear.
If I then install a recessed 12V (SELV) LED tape, horizontally, 200mm above skirting level for the length of the wall, is the entire wall then theoretically a safe zone?
It's really just a theory question, I have installed the light, but the cable routes have been run in zones determined by switches and sockets on the opposite side of the wall.
Cheers,
522.6.6
Cheers,
