DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking Triton shower- please help!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Larac
from United Kingdom
PostPosted: Fri Dec 30, 2005 2:34 pm Reply with quote
My shower suddenly started leaking on Christmas Eve (have to keep turning cold water off at mains) - it is not the showerhead or hose but coming from little 'pipe' at bottom of shower unit itself(could it be the valve inside??). Would I be able to fix this myself (know nothing about plumbing but willing to try)or do you think it will require a plumber? (PS shower is about 6 yrs old)
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Fri Dec 30, 2005 3:23 pm Reply with quote
The little pipe comes from the pressure relief valve. Once opened it cannot be shut, so you will need a new one from Triton. Call Triton and tell them the model and power rating of the shower. You can fit it yourself, but isolate the shower electrically before removing the cover.
Now then, the valve opens for a reason. Most often it is that the heat exchanger is scaled up. Remedy is the same as for the valve. Isolate before removing the cover.
Does that help?
Oh, and isolate before removing the cover...
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Triton Jade electric shower PRD valve fault? Water leaking 10 14480 Mon May 02, 2011 11:18 am
Leaking Triton Opal shower 5 1980 Thu May 29, 2008 3:31 pm
Dripping, leaking shower - Triton 16 260 Sun Nov 17, 2013 2:16 pm
Triton Power Shower Leaking after Central Heating Install??? 5 780 Mon Feb 18, 2008 7:16 am
Triton stabiliser valve leaking 2 60 Sun Oct 13, 2013 8:56 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
