Hoover ACM 15 Soap dispenser leak
3 Jan 2006
Sussex
For about the last month (never before) my machine leaks from the bottom of the soap dispenser draw, it happens during the last stages when the draw is being cleaned out, I have checked the roof of the dispenser and there is no gunge that could cause the problem, it seem as if the nozzle to the back left of the draw is jetting water to the front of the tray (the water pressure seems to high). Can anyone give a reason/solution?
two probable causes usually
1. machine not level back to front ie leaning forward
cure: adjust front feet to raise front and rectify
2. cold water pressure to high
cure: back off slightly with main stop cock
