DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dye from red napkin
This topic originated from the How to page called Dye
Click here to return to the page called Dye.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
westcat
from United States of America
Thanked: 0 times
PostPosted: Tue Jan 03, 2006 6:58 pm    Post Subject:
Dye from red napkin
Reply with quote Thanks
I wiped a spill off my light blue cotton shirt with a red paper napkin and the red dye from the napkin transferred to my shirt. The waiter gave me some soda which took most of it off, but not all. When I got home I washed it in hot water with bleach, but that did not remove it. Unfortunately I put it in the dryer also. I've now tried Zout and also rubbing alcohol with no luck. Going to try hairspray next. Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
b2006
Thanked: 0 times
PostPosted: Sat Sep 08, 2007 11:42 pm    Post Subject:
Napkin Dye stain removal
I know your thread was a year and a half ago, but I think that it's important to share what I've found. I had a black cocktail napkin stain on an expensive shirt from attempting to wipe out another minor stain at a wedding. The black stain was almost 2 inches long and substantial. Had it drycleaned, barely improved things. I was about to throw it away, but I decided to try hydrogen peroxide -- WOW. It vanished IMMEDIATELY and a small black border was formed. I immediately rinsed thoroughly in water and then soaked this part of the shirt in more hydrogen peroxide, washed it normally, and the stain was gone. I don't recommend this with dyed shirts and I would test first. Hydrogen peroxide also worked for me with blood. You have to soak it in hydrogen peroxide for 15 minutes and use a bristle brush and repeat until it's gon. Hope this helps.
b2006
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Sep 09, 2007 12:40 am    Post Subject:
you could have at least written your own post rather than hi-jacking an old one icon_rolleyes.gif
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
b2006
Thanked: 0 times
PostPosted: Sun Sep 09, 2007 4:39 am    Post Subject:
The shirt was blue. Hydrogen peroxide is an oxidizer. Just thought I'd help out the next poor sap that looks up a solution to this problem. My posting added a piece of useful knowledge for the layperson, which apparently you are. Your response was of no value. At least you could have posted your own instead of stealing this one.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Sep 09, 2007 8:29 am    Post Subject:
but if you had read the forum rules you would have known that hi jacking posts is not allowed (forum rule 20)
(lets disagree on the oxidiser, since chlorine (the active ingreadiant is an oxidiser, its just more powerful than hydrogen peroxide)
(froum rule 20)
20) Do not hi-jack posts
(Hi jacking, is adding your question to a post you did not start, it causes confusion)
Moderators will try and split a post when ever possible.
__________________
Forum = Opinions
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 09, 2007 9:12 am    Post Subject:
Bleach / Oxidising agent, same thing really. You would be unwise to attempt to purchase hydrogen peroxide in the UK, unless you want unwelcome attention from MI5.
Hydrogen peroxide is a key ingredient in the manufacture of crude explosives, and as such it's sale has been severely restricted in the UK post 7/7/2005 FWIW I was on a tube (kings cross) when the bombs went off, always felt since then that I was lucky that day.
Mind you I saw a 1 ton sack of ammonium nitrate discarded at the side of the road the other day, I shudder to think what you could do with that.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
