DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hotpoint WMA30 bearing replacement- how to?
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Lower
from United Kingdom
Thanked: 27 times
PostPosted: Fri Jan 06, 2006 11:34 am Reply with quote
Anyone have any advice, guidance or a how to to replace the drum bearings on our Hotpoint WMA30. It's out of the 5 year parts warranty, i have obtained the rear drum section containing the bearings, and i'm going to start stripping down the washing machine tonight to replace it. I've never done a washing machine before but i'm a fully skilled mechinical engineer so i'm going to have a stab.
Any guidance of any sort, other than being told to get a professional in icon_smile.gif , would be appreciated!
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Fri Jan 06, 2006 7:58 pm Reply with quote
I used to work for hp, i admit things have changed but i an confused by your term "rear drum section"
could you post a pic of what you have or describe it more (posting a pic info is in forum information)
do you also have a new spider, and drump plate seal?
Back to top
 Alert Moderators
tiredengineer
from United Kingdom
Thanked: 6 times
PostPosted: Sat Jan 07, 2006 9:52 am Reply with quote
On the WMA you can either replace the bearings or replace the back half of the outer tub.
Did you get the full kit? You definitely need the tub seal as a minimum.
The whole front of the machine comes off to do the change. Take your time and note where you take all the parts off. You shouldn't have to disconnect any wiring, just move it out of the way.
It's a simple enough job, just time consuming.
Unplug your appliance before working on it.
Back to top
 Alert Moderators
Lower
from United Kingdom
Thanked: 27 times
PostPosted: Sun Jan 08, 2006 6:25 pm Reply with quote
the back half of the tub including the bearings would be a better description.
I did about 75% of the job on friday night and finished it on sunday. Not too hard a job for the novice, but somewhat scary as you have to remove virutally every component from the main chassis to get the tub out. The only wiring i had to disconnect was that for the motor and for the element. Working out how the element came out was fun too! I also struggled to get the plasticv dowel pins out that hold the tub to the lower suspension units, but i got there in the end. Not only that i didn't have any bits left over, and it works now i've put it back together.
The shaft seemed to be virtually unmarked around the seal area, so i cleaned it upo with a scotchbrite pad so all discolouration had gone, and no leaks at this point.
Result!
Thanks for the comments.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint WMA30 bearing and spin fault 6 1000 Thu Aug 21, 2008 12:25 pm
hotpoint wma30 wont spin 4 480 Sun Nov 22, 2009 7:21 pm
How to get into hotpoint WMA30 2 920 Fri Oct 14, 2005 7:15 pm
Hotpoint WMA30 Cuts Out 9 120 Thu Mar 19, 2015 8:28 pm
Replacing Bearings Hotpoint wma30 4 1780 Wed Nov 02, 2005 7:32 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
