Pilot light keeps going out
6 Jan 2006
Please help! I have just moved into my new house about a month ago, the boiler worked fine for the first couple of weeks but since then, the pilot keeps going out on a regular basis.
is this some sort of safety cut out? What is causing it? We have had a CORGI guy out to look at it several times, he\\\'s changed the thermo coupling, taken the whole boiler to bits and claened it, and still the pilot cuts out.
one thing - we went on holiday for 2 weeks and it was still working when we came back. so it must be something we are doing that causes it to go out.
it seems to go out about an hour after we use hot water, but this may be coincidence.
Does any of this make sense? please help!
(Boiler = Glowworm 60p)
Have you cut down any trees, or removed any fencing, or put up any fencing, or done anything else outside the house near the flue from the boiler?
It is probably scaled up and the over heat stat trips out the pilot with latent heat after hot water delivery.
Unfortunately few gas engineers seem to know how to treat scaled up boilers.
We usually charge about £180 in the London area.
With an older boiler it might be time to think about a replacement!
Tony Glazier
Tony Glazier
Thanks for taking the time to reply. I dont fancy paying £180 !! Would our service agreement cover this?
Also, the boiler is 6 years old, surely we dont need a new one already?? :confused:
I don't know the boiler do you mean 60B?
If so that doesn't have an overheat stat, maybe the pilot flame is too small or not pointing at the TC or too strong, or a cheap universal (ueless) TC was fitted, get correct manufacturer's part fitted.
