DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wiring downlights?
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
HammerHappy
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 07, 2006 7:29 pm    Post Subject:
Wiring downlights?
Reply with quote Thanks
I want to wire 8 down lights (50 watt Halogen no need for transformer type) in my kitchen. Would anybody be able to tell me the best way of doing this please. I\\\'m thinking of either using 3 junction boxes and join them there or just more simply going from the first light to the next and so on like a chain. Also they are double insulated so i guess i just trim the earth back and leave it? Do i just use normal lighting cable or does it have to be special heat resistant cable? It doesn\\\'t say anything in instructions! Thanks for any help! icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Jan 07, 2006 7:44 pm    Post Subject:
The way to do it is to daisychain them. connections need to be accessible, so using junction boxes all over the place wont meet regs. Use 1.5mm˛ cable.
Its worth noting that's 400w of lighting you will have in your kitchen. How many watts did you have before? How many watts in total do you have on this circuit (incl. this addition)? What rating is the protective device (MCB/fuse)?
Dont snip the earth off. It make be needed in future. Continue the earth through the daisychain if you can, using terminal blocks.
Back to top
 Alert Moderators
HammerHappy
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 07, 2006 8:46 pm    Post Subject:
Thanks i'll daisy chain em then and keep the earth continuity going with terminal blocks. This circuit will have a total of 1100w and will be protected by a 6amp mcb. I understand this to be ok. So the flat grey 1.5mm cable is ok then, it doesn't have to be special heat resistant cable? Thanks for your help again! icon_lol.gif
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Jan 07, 2006 10:57 pm    Post Subject:
yes this is fine. Just checking because a lot of people add extra lights to their downstairs circuit and end up overloading it - 500w outside lights are good at this! icon_lol.gif
btw, i meant to make the point earlier, that 400w is a lot of light. How big is the kitchen? how many watts did you have before?
Back to top
 Alert Moderators
HammerHappy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 08, 2006 9:06 am    Post Subject:
It's a fair size. approx 2.7m wide and about 5m long. I know this does seem a lot of light though. Maybe 6 would be enough but i dont want to create shadows by not having enough light. Thanks for your help. icon_surprised.gif
Back to top
 Alert Moderators
baldelectrician
from United Kingdom
Thanked: 3 times
PostPosted: Sun Jan 08, 2006 1:49 pm    Post Subject:
use these
http://www.screwfix.com/app/sfd/sea/searchresults.jsp;jsessionid=TDKO440NHGNS0CSTHZOCFFY?_dyncharset=UTF-8&q=choc+box&n=&pn=1&pd=1&pi=1&cn=1&cd=1&x=0&y=0
or something like them above each light, then a tail to each fitting.
Personally I would use ELV (12V) lamps with trannys as a 35W )quality - osram / phillips lamp will give the same light as a 50W mains halogen.
Also the lamps last longer and are cheaper to replace.
this makes all connections acessible as you can pull them out of the roofspace to get to them
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
wiring 8 mains downlights 2 1040 Sat Apr 22, 2006 1:24 pm
Wiring Downlights 10 1180 Mon Sep 18, 2006 12:03 am
Need Help Wiring 4 Downlights To An Excisting Light. 4 480 Wed Jul 02, 2008 2:14 pm
Wiring for 5 downlights 7 460 Fri Sep 18, 2009 5:29 am
Wiring Downlights 6 1720 Mon Jul 11, 2005 9:45 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
