DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer not dimming
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
asarco
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 08, 2006 2:11 am    Post Subject:
Dimmer not dimming
Reply with quote Thanks
While replacing a fused incandescent bulb, I accidentally made a short, and the main switch automatically switched off. After re-connecting the main, the dimmer for that bulb doesn't work anymore, only turns on-off the light but no dimming.
I opened the faceplate (2 gang) and found two black MK 1 way switch boxes inside, min 40w max 200w. Could this switch be repaired (e.g. change a fuse inside) or replaced (only the switch), because I've been looking on the web and only could find the complete faceplate with knob, it seems a complete waste to buy a new 2 gang unit to replace only a half-broken one.
Thanks!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Sun Jan 08, 2006 9:59 am    Post Subject:
Unless its a grid plate, you are limited to replacing the faceplate.
And it'll be the triac in the dimmer thats gone, dimmers don't usually have fuses and if it did, the light would be off
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Halogen 'Rail Light' - Dimming but no dimmer! 5 440 Thu Jun 08, 2006 10:16 pm
Any ideas why dimmer stopped dimming? 2 380 Mon Feb 06, 2006 11:27 am
Dimmer keeps dimming 7 400 Wed May 30, 2007 8:20 pm
Dimmer not dimming 2 340 Fri Jun 01, 2007 8:22 am
Dimmer Not Dimming (2 Way Lighting) 4 300 Mon Jan 15, 2007 12:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
