Joined: 10 Jan 2006 Posts: 5 Location: Nottingham, United Kingdom Thanked: 0 times
Posted: Tue Jan 10, 2006 10:03 am Post Subject:
pipes into the rad
i want to replace a single rad with a double without draining the system and replacing the valve and lockshield. The trouble is the rad i bought has no pipes to join it to the valves and the existing ones on the old single are a bit manky ().. can you buy new pipes or do I have to extract the old ones (which don\\\'t have a nut on??)
Posted: Tue Jan 10, 2006 10:19 am Post Subject:
yes, it has the threaded holes but not the pipes (which you're saying are part of the valve?).. can you buy new pipes to fit the existing valves? I assume it's all standard stuff? I don't want to have to get the old pipes off the single rad and I assume they have an internal hex or something as there's only the nut for the valve end (smooth pipe going into the old rad..)
Joined: 06 Oct 2004 Posts: 1052 Location: United Kingdom Thanked: 0 times
Posted: Tue Jan 10, 2006 10:32 am Post Subject:
Yes, it is a struggle, but I think I see your question. When you say 'no pipes', you mean the piece that fits into the rad between the valve and the rad ?
When you undo the large nut on the valve and pull the valve away from the rad, the threaded part that the valve was screwed onto and which is fitted into the rad can be removed from the rad (surprise, surprise) with a radiator spanner. It is basically a box shaped end which (as you said) fits inside the connector allowing you to turn it. Yes these are all standard parts and available in most diy sheds. Just make sure you know your pipe size when buying new valves, 15mm, 10mm or even 8mm.
Joined: 24 Jul 2003 Posts: 18663 Location: London, United Kingdom Thanked: 62 times
Posted: Tue Jan 10, 2006 11:23 am Post Subject:
But he won't be buying new valves to fit the actual, vertical, copper, 8/10/15mm pipes, only for the part which goes into the rad.
There are two sizes for the union between the rad valve and the radiator piece, 3/4" sbp and 1/2" bsp. Most non-thermostatic valves are 3/4". (Nut is about 1 1/4" across).
If you buy a cheap valve you can just use the part you need, but because it wasn't designed to fit that particular other half, you may need something to stop it leaking, like several turns of ptfe or sealer like fernox LS-X. Don't put either on the threads of the union - they won't even be wet. Put plenty of ptfe on the rad fitting end though.
Posted: Tue Jan 10, 2006 1:06 pm Post Subject:
thanks for the help guys.. i bought two cheapo 15mm valves and a radiator valve allen key/box key. Hopefully I'll be able to use the two rad connectors off these valves and not have to replace the existing valves (don't wanna have to drain the system).
interestingly when I asked the bloke in B&Q if this allen key was the right size to screw the valve parts into the rad he said 'no, use grips'.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
