- Joined
- 27 Jan 2008
- Messages
- 23,661
- Reaction score
- 2,665
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Read the fridge or freezer details and we will get power used when switched on but as they get older the insulation can break down and as a result the motor runs longer or it can loose some gas again motor runs longer.
Power meters today are cheap so it is simple enough to plug into one and measure over 24 hours the power used, however once we have these reading how can one check on if it’s reasonable for the fridge or freezer?
With brand new one gets a sticker in my case 277 kWh / annum which works out at 0.759 kWh / 24 hours allowing it to cool down first I get 0.810 kWh / 24 hours. Clearly ambient temperature and other factors will alter power use so what are required are some figures for a 288 litre fridge with a 112 litre freezer for an A++ rating. What is the expected range over a 24 hour test?
With older units it's hard to find any info on power usage. Since my Samsung RL60GZEIH is new I have the sticker which came with it but the older units the info is not included in manual and as my measurements show even a new one did not quite hit the mark.
Any idea where one can get the info for older units?
