HELP Vokera linea 24 code 07
11 Jan 2006
Aberdeen
The error code on my 4yr old Vokera Linea 24 flashes 07. It seems to reset and fire up ok but once the required temp is reached and the boiler shuts itself off, it refuses to start up again unless i reset it. Any ideas as 07 isnt mentioned in the user manual. Im getting cold !!! :?: :?:
Fault codes are listed in ins & service manual which you should have (a legal requirement to be left by installer since about 1984)
Primary thermistor. It's either screwed into the main heat exchanger on the right hand side or screwed into the pipe leading up to the main heat exchanger on the right hand side. It's chrome/blue plastic with 2 thin brown wires leading to it. It is NOT a dry pocket ntc sensor so it will involve a drain down of sorts. Part number 8484.
