DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Leaking bath waste
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
deanjmason
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 12, 2006 2:17 pm    Post Subject:
Leaking bath waste
Reply with quote Thanks
I have connected the waste outlet of the bath to the trap using ptfe tape but the connection still leaks when water is released. Any help appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Thu Jan 12, 2006 4:32 pm    Post Subject:
The trap is leaking?
Change it or make sure the washers are fitted properly. Make sure it is lined up with the waste pipe properly and not at an angle. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
deanjmason
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 12, 2006 5:22 pm    Post Subject:
Thanks Bahco. The leak is from where the trap is screwed on to the bath outlet.
I will check points mentioned.
Back to top
 Alert Moderators
newboy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 12, 2006 8:00 pm    Post Subject:
Take the PTFE tape off - the trap seals to the waste with a rubber seal which needs to be fully tight to the underside of the waste. The PTFE may be stopping you from screwing the trap fully home. You only need to use PTFE where the threads form the seal - not in this case
Back to top
 Alert Moderators
deanjmason
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 16, 2006 11:42 am    Post Subject:
Thanks all for you help. Fitted new washer and removed PTFE tape and problem solved.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leaking bath waste pipe 4 580 Fri Jul 22, 2005 2:09 pm
Bath Waste Pipe Leaking 2 600 Tue Jun 20, 2006 1:27 pm
New bath waste leaking 7 240 Tue Aug 11, 2009 6:47 pm
Bath Pop Up Waste Leaking 9 5820 Wed Jul 13, 2005 6:51 pm
Bath waste leaking. Help! 12 1000 Tue Feb 28, 2006 11:54 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
