Engineered Floors - confused
1 Mar 2011
Telford
Hello
Can I have recommendations for places to purchase good quality oak engineered flooring please? I google, and come up with so many options I thought it was worth asking for recommendations..!
Mike
V4 is up there as the best in the uk
Also kahrs.
They are about the only 2 I do. Both top quality and good to fit.
Thanks - hadn't heard of V4 before.
Everything seems to be made in China these days, is there a UK or European manufacturer or must I submit my hard earned to the far east?
Have ordered a box of oak 190mm wide, 15mm thick with a 4mm wear layer. Sample looks well made, 7 layers of ply with 4mm oak on top. Approx £40 psqm inc vat and delivery. Have ordered samples of junckers and k4 to compare against.
K4 and the one i've ordered are made in China. Supplier told me they are not FSC certified so can't show logo, but assure me the wood is FSC. Guess I should expect to see an FSC logo on the box, with cert number? When it arrives.
Is engineered oak from China capable of good quality these days? I've seen plenty of don't touch with a bargepole comments here and elsewhere.
Anything else I should check for? Am laying on elastilon, most likely.
Mike
So can chinese boards be good quality, or should I avoid? I ordered a box and two of the planks are bowed, but I understand this is quite common.
Also is it ok to lay a 190mm wide board as a floating configuration in a room which is 7x5.5m, on solid concrete, or would glue be better?
Mike
