DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
new false ceiling for downlighters
This topic originated from the How to page called Preparing Walls and Ceilings
Click here to return to the page called Preparing Walls and Ceilings.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
cormier
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 28, 2003 1:35 pm    Post Subject:
Reply with quote Thanks
I am installing some new low voltage downlighters in my kitchen and need to fit a plasterboard false ceiling to hide the new wiring. The existing ceiling has 12.5mm plasterboard attached to joists which are 200mm by 45mm in cross section and spaced 400mm apart. The false ceiling would be attached to softwood struts (25mm by 75mm cross section) which are themselves screw attached to the joists. The room size is 5.5m by 3.4m. My concern is over the ability of the existing ceiling to take the weight of the new plasterboard. Are there any rules of thumb which can be applied or calculations made. I had intended to use 12.5mm plasterboard but now feel that 9mm board may be more suitable. Any advice would be much appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Oct 28, 2003 4:54 pm    Post Subject:
I can't see a problem with this only that you can't see the cable wire above when screwing the 75mm x 25mm flat onto the ceiling.
There're many ways of doing this,
Personally I would take the ceiling down as you got to get some plasterboards to put back up again anyway,messy I know but easier with the wiring.I'm guessing that you've a flat roof as you cannot access to wiring from the top and also thinking can you not run the wire inside the ceiling once you cut out the holes ?
I think that the downlighters need air-flow as they get hot, unless you already got air-vent in the roof section.Best to check with the electrician's first on this forum.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 28, 2003 6:03 pm    Post Subject:
You can get LED bulbs to replace halogen - no heat problems.
Does anybody have experience of how well they work?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Oct 28, 2003 8:57 pm    Post Subject:
see post in electrics forum
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Mr Impedance
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 31, 2003 8:50 am    Post Subject:
If you can try to get some fixings into the wall as well as the joists I think that will hold it I did same thing in my kitchen whitch is 6m by 4.5m and its solid. About the downlighters needing airflow as long as you dont place anything directly on the lights you will be O.K
My advice is to After you stud the ceiling outaround about where you are havin the downlighters smash a hole in the old ceiling This will be very messy Clip the cable to the ceiling to the position of the lights leave a bit of slack so you can drop it through the new plaster board. Work out on your new plasterboard where you need to cut out for the downlighters. Then connect up and hey-presto.
Good Look
Chris
Back to top
 Alert Moderators
Freddiynot
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 09, 2006 5:57 am    Post Subject:
LED replacements for downlighters
My MR16 LEDs came from ultraleds Subjectively about the same brightness as a 15w halogen, but the colour is different, a bluish white, a bit like bright moonlight. Wonderful for reading by. Consume about 1.2W (so saving electricity) and don't blow every few months.
Slightly warm to touch after having been on for an hour or so.
Also available in warm white and a 240V G10 version, but I haven't tried these. Subjectively warm white is not as bright as cool white, but it might be more suitable for a kitchen if you want the food to look better.
Hope that helps.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Sep 09, 2006 10:56 am    Post Subject:
Thanks for the thought, but to tell the truth I've not been waiting for 3 years for an answer....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
False ceiling advice 5 4140 Tue Jan 04, 2005 11:07 am
False Ceiling Advice 8 400 Wed Aug 26, 2009 6:30 pm
Bathroom re-fit ventilation/false wall advice 6 2880 Mon Jan 15, 2007 10:43 pm
Wiring downlighters 2 1540 Fri Sep 27, 2002 12:32 pm
fitting low voltage downlighters to existing circuit? 3 4600 Sat Sep 28, 2002 7:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
