Just fitted electric 10.5 Essentials Elecric Shower. Took old 20 year old Mira ordinary hot and cold shower out and used same cold water connections. No water pressure, no heat, please help
Is the cold water connection coming direct from mains supply (with high pressure) or is it coming from your water cistern/tank with lower pressure. As far as I know most electric showers are for mains supply.
The installation instructions should clarify the requirements.
