Washing M/C Drainage
Syp
30 Oct 2003
Does anyone know where I can beg, scrounge or borrow a \\\"flexible endoscope\\\" on the cheap. I have a property abroad with drainage tube for a washing machine. This will take a normal water flow but not the surge when the m/c empties. I\\\'ve tried all known mechanical & chemical unblockers to no avail. I think there may be something lodged in the pipe just around the bend. Unfortunately unlike UK properties the pipe (& U bend) is in the wall & doesn\\\'t re-appear the other side into a drain. It travels down through the wall never to be seen again. My one hope is a flexible edoscope to identify & hopefully resolve the problem. My last resort is to start knocking the wall down to get at the piping, but the problem may be some distance away. Can anyone help?????
the short answer is no
sorry personally never heard of a camera small enuff for waste pipes
An flexible edoscope is used by doctors to examine the internal passages of the human body and would therefore be plenty small enough
Don't know if you can hire one of these
Can you not also put in a garden hose with maybe a flat copper pipe on the end to get more water pressure at the bend?
