Will moving the header tank higher and extending the vent to suit cure air being sucked in the system through the vent? I fitted an Airjec which has helped but there is still some air getting in through the vent (tested by holding a jar of water over the vent outlet and the water was sucked in the vent). The tank is about 4 feet above the vent joint which is now in to the Airjec together with the cold fill, feed from boiler and feed to pump which is 9" above the Airjec.
