Been reading the forums for a while, learned lots, be gentle with me.
I've had a trawl but can't see anything already posted, please don't flame me if it has been discussed in the past.
I have a bathroom fan with timer and LV lights on one switch (switch located outside bathroom). The fan has a live feed (but no 3 pole isolator or FCU, yet!) from the lighting circuit. The switched live is connected to the wall switch, and all is fine.
However, I've gone and changed the switch for a dimmer. The dimmer is a Lutron Telume TIR-ELV500 (good price on Ebay) and the fan is an Addvent 100 IDT (std 4" job). Everything seems to be working just great.
The fan comes on when the lights are switched on (even on the lowest setting), and it stays on fine. When the lights are switched off, it over-runs on the timer as it should and then switches off. So everything seems OK.
But I'm still worried. I'm not sure that sending a reduced voltage to the SL on the fan is harming the timer. I've checked with Lutron, and they were kind of OK about it, and I rang Addvent but their guy didn't really seem to have much knowledge. I needed to explain twice that I wasn't dimming the live feed, only the switched live to the timer. He was really not sure whether this would be a problem.
Can anyone advise please?
Thanks.
Thanks.
