Electra AWM 1100 - stopped and will not now start
18 Jan 2006
Somerset
The program stopped during the rinses, still full of water. I have now drained (manually) and removed the wet clothes and tried to start a program from the beginning. The On indicator lights up and it clicks once (think this is the door lock) but then does nothing. Any idea's??
Thanks.
i think it will be your module on the bottom left hand side of your machine from the back. unplug from power, remove screws that hold plastic case and then remove board and check for burn marks.
good luck
Can't see anything like a burn mark. All looks OK. Checked connections as well. Any idea what to try next? :cry:
a sure way to tell if it is your module is as follows. re-connect board so machine is ready to use. remove lid. you will see a round object,this is the pressure switch. remove the tube from the bottom of switch and find a piece of tube you can attach and blow down.set your machine on a programme and when you here the click blow down tube. if your pump starts running it is 100% your module at fault
