Joined: 22 Jan 2006 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Sun Jan 22, 2006 1:36 pm Post Subject:
fitting a wood door to upvc frame
i would like to know what would be the method for fitting a wooden external door to a UPVC frame and if this is possible at all. Ive been told by severall window manu. that this can not be done. Any suggestions?
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sun Jan 22, 2006 2:22 pm Post Subject:
Re: fitting a wood door to upvc frame
seem to have answred your own question
probably has to do with timber expanding
__________________ Do you like music Mr Finch?
Forum = Opinions
Joined: 12 Jul 2004 Posts: 5771 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Wed Jan 25, 2006 6:10 pm Post Subject:
they each have the hinges in a different place
the doubleglazed doors are on the face where as the wooden doors have the hinges fixed along the edge and the hinges tend to pivot at a different point to allow the d/g seals to work properly
__________________ big all
we are------------------ all still learning
Joined: 04 Oct 2007 Posts: 1 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Thu Oct 04, 2007 11:35 am Post Subject:
It has become the fashion to fit ether timber or composite doors into pvcu frames. Retro fitting though can be a messy business. things to considder are. Frame rebate size and lock positions as pvcu doors tend to be thicker and the lock located closer to the edge of the frame.
There are a large number of hinges on the market for doing this job. but its simpler to replace the frame at the same time.
Joined: 26 Sep 2007 Posts: 97 Location: Worcestershire, United Kingdom Thanked: 0 times
Posted: Thu Oct 04, 2007 12:30 pm Post Subject:
uPVC doors tend to have several latch points up the door's leading edge side of the frame, a timber door would use a mortice lock. You will therefore end up with only one locking point in the weakest part of the frame - the lip on the edge, rather than the strip screwed into the reveal.
Pull the frame out and install a proper external grade timber frame, it will hold the door more firmly and allow secure locking.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
