A Ring Main Spur
23 Jan 2006
Hampshire
Could someone please advise me on the following;
I need to add additional sockets to my ring main, there is only one socket anywhere near the desired location of the new sockets. I actually need to run two double sockets and one single socket to accomodate my needs. I have been told that if I create a mini ring main from the existing sockets then this will suffice and be safe, certainly safer than running 3 (inline) spurs. Does this sound correct and workable?
Regards
Kevin.
it would be better if you were to break into the ring and make the new sockets a part of the origonal ring
but also as its for "your needs" you are not by any chance moving your pc to another loaction in your house are you? if so why not buy a "serge protected extension lead" and just plug that in.
I have one and it has saved my pcs from going bang in the storms we had a few monhs ago
Hi Breezer, Thanks for reply, no it's not for a PC it's to set up a Kitchenette in an annex for my mother, I have spent today trucking the cable, recessing the boxes into the wall etc etc and was going to connect it up tomorrow, but am having a few worries having read that I should only have one spur from each ring main socket.
What are the risks?
Kevin.
well if its for a kithenette load will be high so it must be on its own ring, not spurred from anywhere and also are you aware of part p (if not try a search)
Not sure I've explained this properly, will it really be that high a load?? I have a separate 30 amp feed for the cooker, the washing machine and fridge/ freezer will be plugged directly into the existing ring main double socket..the spur ring will carry a kettle/ toaster & 60 watt light...is this too much?
You can't create a 'mini ring' off a ring, it'll unbalence the load on the main ring and has the potential to overload one leg of it.
You've got a few solutions
- install a new ring for the kictchen area (best idea)
- install some additional sockets on the existing ring (not a bad idea)
- install a single unfused spur off the existing ring (all right if a single outlet is sufficent)
- install a fused spur with multiple outlets off your existing ring (not really advisable for a kitchen environment)
you said it was for a kitchenette, my thinking of a kitcentte is a small kitchen within a larger property as well as the existing kitchen
if this is the case then the whole kitchenette should be on its own ring.
lets say Kitchenette (a) and main kitchen (b)
a puts on w/m and kettle , b does tumble drier and toaster
wm will draw 13A to heat water
td will use almost 13A to dry clothes
1x wm & 1 td on 1 ring is 26A. ring only supplies 32A
by having both a and b on own ring each has 32A available
although it will not often happen it will happen, or if a is spured from house ring it reduces availability for other appliances.
Kitchens should always have their own ring
and also you must be aware opf part P, come the time to sell the house new owneres will want to see part p certificate
This ring is separate from my my residence ring, the only other areas on this ring are two bedrooms, based on your example would seem very unlikely for overload to occur as these rooms only have TV's?
Thanks for part p advise I am investigating, looks as though I may have to call in an electricial to connect up, but I could certainly do the work myself and just have them check it?
What exactly do you mean by "mini ring"?
You need to read some more - that is almost certainly not going to work, unless you mean that you'll notify your LABC, pay their fee, and also engage an electrician that they are happy with to inspect & test, and for the total cost of that you could just have a registered electrician do the lot...
Having spoken to an electricial this morning the answer was clear! Rather than have 4 wires going into the socket, leave two out and join them together thus having an extended ring main...easy, would have thought one of the experts on this site would have worked it out!
As for part p, the room used to be an annex, the annex was made part of the house 7 years ago, I am turning it back, how does the authority or anyone else for that matter know when this was completed, surely every house would need an electrical survey in order to make part p legislation enforcable.
Thanks for absolutely no help whatsoever.
Regards
Kevin.
Regards
Kevin.
THEY DID WORK IT OUT! READ THE REPLIES FFS
And if you're using the new cable colour schemes, they will know the install was completed post Jan05! ;) oh well eh ;)
