Beko WM5120: Fault code
16 Jan 2012
Uk
We are using a beko WM5120 washing machine. Only a couple of years or so old and not heavily used. The machine would not spin, and had clothes inside. I drained from front to open door and empty. the drum did run once afterwards, but I am not sure how managed that. Anyway, I found this error code post from a few years ago. I went through it, and the resulting STEADY ON light was above "quick wash". Can you tell me what this code relates to, please. Thanks.
beko
turn machine off select 90 deg cotton press and hold start, switch on keep holding start for three secs it will then flash
turn knob to spin press start light codes as follows
prewash .................................. NTC
main wash ................................no heat
prewash and main wash.............. constant heat
rinse......................................... no fill
prewash and rinse ......................no drain
prewash main wash and rinse....... pressure switch
main wash and rinse ................... tacho/ pcb
rinse and cond ............................ no motor action
to reset error codes hold start for five secs
