I have a CH problem thats been mentioned a few times before i.e upstairs rads OK-ish, downstairs cold. My setup is old backboiler with cylinder and pump/3port valve upstairs. Pretty much all the pipes around the pump and cylinder get very hot very quickly and the upstairs rads heat up in sequential order from pump with one closest to pump being the hottest and 4th in line being warm. No sign of any heat downstairs. I have done loads of research and testing and can pretty much exclude airlocks, bleeding (rads and pump) , balancing, sludge block, blocked feed etc. having searched this forum I suspect my problem is the pump and that the upstairs rads get hot via gravity but i can defintaly hear the pump spinning at different rates depending on speed. So my questions is how can i confirm its the pump? I saw one suggestion which suggesting dismantling pump by taking off using alan keys and then switching it on to see if it spins. Another suggestion was to stick a drilll/screwdriver bit through the front (not sure i understood this) I plan to have a stab at replacing the pump at the weekend but would welocme any other advice. B&Q have a selection of pumps so is there anything i should look for to make sure its ok for my needs? Thanks
