- Joined
- 19 Jan 2005
- Messages
- 1,171
- Reaction score
- 41
- Country
Wonder if I can pick your collective brains? (Esp kevplumb!)
Having a new shower fitted (by 'professionals') - twin control thermostatic concealed valve, where before there was just a combined bath tap/shower mixer. Have a gravity fed system, not got combi boiler and have Showermate 1.4 bar twin pump which supplies the bath taps (and now the new shower).
The problem is that when I turn on shower, no water at all flows and pump doesn't start. However, if I turn on the hot or cold bath tap momentarily, this starts the pump and the shower will then work on it's own. However, leave it for an hour or so and the problem returns. What I don't get is that before the shower was fitted, even if the pump was turned off, I got some water out of the taps - but just a dribble. So reckon it must be something to do with the shower not the pump?
The pump doesn't have non return valves, so I reckon the ones in the shower should be left in? Also I've noticed that the incoming and outgoing pipes to the pump is 15mm, but this then changes to 22mm. I've also taken the shower hose off, but no difference
Any thoughts on what might be the problem??
I'm starting to get a bit whiffy and will need a shower soon....
SB
SB
