Hi..
I have a Glow Worm Xtrafsat 96 (Saunier Duval) and the High Temperature Thermostat keeps tripping. I recently had quite a clogged up system so I drained the system, added a cleanser, ran it for 4 weeks and the drained it out again. I then added some 'preserver' upon refill and since then every couple of days the HTT just trips leaving me with no hot water or heating (the boiler just humms [water pump] but won't 'let itself' ignite). I then remove the cover to the combustion chamber and press the reset 'nipple' on the sensor with the tip of a screwdriver. It's then OK again for a day or so.
Couple of notes that may help diagnose this:
The boiler itself (when the heating is working) is on nearly 100% of the time. I've got 11 rads, but I feel the boiler shouldn't have to work that hard (and I'm sure my gas bill is growing!).
I've replaced the HTT so as to elimnate the possibility of a faulty part. Alas, it still keeps cutting out.
Can anyone help? The plumbers I have called seem to have less of an idea than me!
Many thanks in advance.
