M
marksi
House is 10 years old, plastic microbore pipes, oil fired boiler. System is pressurised at 1.5 bar. Pump is turned up full (3). There are four radiators downstairs and 4 upstairs. A main feed comes from the boiler in a large pipe which splits into two... there is then a 4-way manifold on each pipe, one feeding upstairs and one feeding downstairs. Each radiator (except one) has a TRV on it and they were fitted when I moved in last year.
I have one radiator on each floor which is cold (or rather, not nearly as hot as the others). They have been cleaned out and it's been confirmed that the pipes are not blocked. There appears to be no flow across them - the valves and a little area at the bottom of the radiators are hot, but the rest of the rad is only tepid. All other radiators are very hot. System is balanced, and turning off other radiators doesn't appear to make any difference to the flow across the two which don't work.
Now completely stuck for ideas on what to do next, plumber has suggested replacing all the pipework which I don't want to do as it'll cause every room to be upset (not to mention the cost, which I can't afford). Help!
