DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
voltage drop
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
Frank35
from United States of America
Thanked: 0 times
PostPosted: Fri Jan 27, 2006 3:37 am    Post Subject:
voltage drop
Reply with quote Thanks
how do you calculate voltage drop?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Jan 27, 2006 11:10 am    Post Subject:
resistance of both current carrying cores multiplied by operating current.
Back to top
 Alert Moderators
Frank35
Thanked: 0 times
PostPosted: Sat Jan 28, 2006 3:01 pm    Post Subject:
voltage drop
Here in the USA we use this formula 2LAR/1000. L=length A=amps R=resistance we have a table in our code book that gives the resistance per 1000'. Do you have something similar?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Jan 28, 2006 5:39 pm    Post Subject:
In BS7671 (also referred to as the iee regulations) for the UK we have tables for volt drop for a given type of cable and csa of conductor. This is given in mV/A/m, millivolts per amp per meter.
(mV/A/m figure)*Ib*L / 1000 = volt drop where Ib is design current of circuit and L is length in meters.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sun Jan 29, 2006 12:06 pm    Post Subject:
Re: voltage drop
pretty much, we generally give the resistance of both phase cores in the table rather than doubling it afterwards but yeah otherwise pretty much the same.
Back to top
 Alert Moderators
DDoyle
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 29, 2006 2:57 pm    Post Subject:
We use the same in the UK.
We have tables in the back of our Regs Books (BS7671:2004) that gives the maximum load of a particular size and type of cable, giving several different ratings for installation method. Then below this table will be another which gives the volt drop for the given cable.
The calculation is mV*I*L/1000
or Volt drop per amp per meter * Current * Length and divided by 1000 to give the correct voltage. In the uk we are limited to 4% of the supply voltage or 9.2V@230V
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Voltage -- today's wireless broadband routers multi-voltage? 17 2500 Mon Aug 28, 2006 8:26 pm
low voltage transformers 4 760 Tue Feb 24, 2009 10:27 pm
Low Voltage Lights 8 1340 Wed Jul 05, 2006 1:37 pm
low voltage lighting: higher current? 5 1040 Sat Nov 19, 2005 8:21 am
supply voltage irregular cyprus 6 960 Wed Sep 07, 2005 8:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
