Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Posted: Sat Jan 28, 2006 4:37 pm Post Subject:
As long as the MCB is compatable with the consumer unit you wish to put it in, and a 40A device gives the correct level of protection to the circuit connected to that fuseway, then yes you can, unfortunatly I'm unable to advise you on either point as I've dropped and broken my crystal ball and have yet to aquire a replacement
Joined: 28 Jan 2006 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Sat Jan 28, 2006 5:59 pm Post Subject:
thanks for info,the make of c/u is dorman smith,100amp switch and im upgrading my shower from 7.2 to 8.5kw hence i have to upgrade the mcb as the existing one is a 32amp
Joined: 11 Jan 2006 Posts: 97 Location: Merseyside, United Kingdom Thanked: 0 times
Posted: Sat Jan 28, 2006 6:12 pm Post Subject:
6MM takes at best around 40A thats not takin into concideration distance of thermal effects i.e insulation or installation reference methods.
My recomendation whould be to replace with 10MM, But 6MM is a min
if the run is too long or the effects on the cable are too great the MCB will trip out protecting the cable if this happenes you will have to upgrade the CSA of the cable
Posted: Sat Jan 28, 2006 6:19 pm Post Subject:
Good this also means that if you upgrade in the future the cable will be ok and you can go upto larger KW showers. I have a 11Kw shower on a 50A MCB with 10MM.
Tip : get a thermostatic shower, more expensive but better in the long run , when someone turns the cold tap on you dont get burnt when the temp changes its a constant temp.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
