DIYnot
Local | Network
   DIYnot > Forums
Local | Network
painting interior woodwork
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
painter
from United Kingdom
PostPosted: Mon Jan 30, 2006 3:06 pm Reply with quote
Please help. The woodwork in my house is all painted with white gloss. It has brown marks where I presume all the knots in the wood are. Is there a way to permanently cover these marks without having to sand down to the bare wood.
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 6 times
PostPosted: Mon Jan 30, 2006 4:33 pm Reply with quote
Whenever anything "bleeds through" a primer or paint, what's actually happening is that some chemical in or on whatever you're painting over is dissolving in the paint you're using and diffusing through the wet paint film to it's surface where it discolors that surface.
MOST things that are soluble in water are not soluble in mineral spirits and vice versa, so if a stain bleeds through an oil based paint, it generally won't bleed through an emulsion paint and vice versa.
The brown spots you're seeing are probably "tannin" from the knots in the wood, and tannin is soluble in water.
I'd use an INTERIOR oil based PRIMER to paint over those spots only, and allow to dry, and then paint over that oil based primer with paint to match the rest of the woodwork.
coupla PS's:
PS #1:
One of the primary differences between INTERIOR and EXTERIOR oil based primers is that if an exterior oil based primer claims that it "breathes", the way they can make it do that is by adding enough coarsely ground white extender pigments to it so that it actually dries porous.
You see, oil based paints won't allow moisture to pass through them the way emulsion paints will. But, it's important that wood or masonary on the exterior of a building be allowed to dry out if it gets wet from humidity passing outwards through the walls. So, in order to allow water molecules to pass through an oil based exterior primer, what they do is add enough large coarse "extender pigments" to that primer so that as the solvents evaporate from the primer and the binder shrinks as a result, tiny air passageways open up between those large extender pigments so that the primer dries porous. And it's this porosity the primer manufacturer will point to to make the claim that the primer will allow any wood or masonary under it to dry out.
Interior oil based primer won't dry porous. Also, because wood outdoors expands and shrinks MORE with the larger variations in relative humidity you get outdoors, exterior oil based primers need to dry to a softer film that can stretch and shrink more without breaking (and cracking and peeling off).
PS #2:
The EASIEST way to help eliminate brush strokes in any paint is to thin it a bit. With latex paints, you thin with water. With oil based paints you thin with mineral spirits. The more you thin a paint, the more it shrinks in film thickness as the thinner evaporates from it. So, put a bit of interior oil based primer in a small container and thin it about 10 percent up to say 20% by volume with mineral spriits (also called "paint thinner") to help eliminate brush strokes. Put on a second coat if you want to compensate for the thinner dry film thickness it will dry to.
On vertical surfaces, thinning the paint can lead to other problems, notably the paint "sagging" on the surface as it dries. Some companies make "paint conditioners" which will thin oil based and emulsion paints without lowering their viscosity so that you can achieve a smoother paint job on a vertical surface using a brush. Look for "Penetrol" for oil based paints and "Floetrol" for emulsion paints in your paint store, both made by the Flood Company.
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Mon Jan 30, 2006 8:40 pm Reply with quote
Sorry Nester...that wont work over here...we dont have an oil based primer that will cope with that aside from aluminuim or (aloo-min-am as you lot say icon_lol.gif )..wood primer which is dark and will need touching up with a couple of coats of undercoat first.
Painter...do a search for 'styptic knotting' or white knoting its ethenol based and will block the stains
If you cant get that I think zinseer will do the trick.
Nester..another one for the 'lost in translation' file...mineral spirit is called white spirit here....we also have turpentine substitute (which shouldnt be used for thinning gloss)
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 6 times
PostPosted: Mon Jan 30, 2006 10:40 pm Reply with quote
Thanks for catching me on that one, Zampa.
Will try to remember to say "white spirits" instead of "mineral spirits", too. icon_wink.gif
Back to top
 Alert Moderators
painter
from United Kingdom
PostPosted: Tue Jan 31, 2006 2:07 pm Reply with quote
Thank you for the info.... Off to the shop to see if I can buy white knotting
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Repainting interior woodwork-what paint would you recommend 5 120 Mon Feb 27, 2012 8:49 am
best white paint for interior woodwork 9 420 Sun Aug 31, 2014 8:50 pm
re-painting woodwork. 3 320 Sat Feb 24, 2007 4:43 pm
How long to leave woodwork before painting? 5 80 Tue Jan 01, 2013 11:39 pm
Painting woodwork next to stair carpet 2 140 Tue Mar 13, 2012 4:20 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
