Dear All,
a plumbing newbie and useless person here.
Story is this, had a loft conversion done, which needed the header tank moved and 2 new rads installed and one moved.
previoulsy the system work very well. It is an old thorn bolier.
However, the new radiators would not heat up, have had the plumbers back many times with the following effects
1 Your pump in not man enough - therefore father in law and I upgraded pump no joy
2 you need a new boiler - ignored this one
3 they turned up and got them working
4 the rads went cold the next day. When bled no air or water came out at all, you could leave the vent open,
5 All other rads are not as hot as they were
6 The plumbers returned got it all working, but then it has failed again, One stays cold, the other is lukewarm and needs bleeding everyday and black water comes out.
The plumbers have been back 4 times with no joy, any tips please
thanks
thanks
