leonuk
Joined: 30 Jan 2006 Posts: 1 Location: Nottingham, United Kingdom Thanked: 0 times
Posted: Mon Jan 30, 2006 10:00 pm Post Subject: pressure prob i think???help |
just installed a triton aquatronic 3+ 9.5kw shower into our bathroom,its connected straight to the mains when the shower settings are turned down to cold the pressure is fine but when i turn the temp up the pressure goes and just trickles out!! is this because there is not enough pressure frm the cold water feed(mains).just to let u know i live in a ground floor flat not a house some one pls help |
Prof.plumb
Joined: 09 Feb 2006 Posts: 188 Location: Leicester, United Kingdom Thanked: 2 times
Posted: Thu Feb 09, 2006 2:47 pm Post Subject: Your problem |
Very strange. Firstly let me explain how an electric shower works.
Cold water from the mains comes in and it is heated via an element. similar principle to a kettle if you like. Now, obvioulsy when there is a demand for cold water the pressure is good as the shower is not having to heat the water up. And when the demand is for hot water the shower is put through its paces.
Now, the problem you are encountering i would say would be common place with a 7.5Kw shower or and 8Kw shower but 9.5Kw showers usually have a good flow rate.
There are a few things that could cause this problem.
1- Mains water was isolated at stop cock and hasn't been fully re-opened.
2- You may have assumed it is mains you have tapped onto but if it is tank fed cold water then this would explain the problem immediately.
3- what power is there at the shower if it is 230 V the performance of the shower may only sort of be around 8Kw opposed to 9.5 at 240.
4- it could be a faulty element.
My advice to you is check the shower is installed correctly and if it is call the manufacturers as they cover all products for a year and get them to come have a look.
Best of luck! |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Thu Feb 09, 2006 3:06 pm Post Subject: |
Measure the flow at showering temperature. You can only expect about 4 litres/minute. |
Softus
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
chrishutt
Joined: 20 May 2005 Posts: 5346 Location: St. Pierre and Miquelon Thanked: 2 times
Posted: Sat Feb 11, 2006 9:54 pm Post Subject: |
Leonuk, ignore Plod.plumb - do what ChrisR suggests. __________________ Let's face FAQs. |
dal5band
Joined: 03 Mar 2005 Posts: 417 Location: Surrey, United Kingdom Thanked: 1 time
Posted: Sat Feb 11, 2006 10:11 pm Post Subject: |
yup - electric shower flow rates are not very good - esp in winter as the incoming water is at its coldest.
What you think is a trickle may be the best the shower can do. Maybe you need a finer showerhead to create a bit of a spray. |
