jockie
Joined: 31 Jan 2006 Posts: 3 Location: London, United Kingdom Thanked: 0 times
Posted: Tue Jan 31, 2006 11:53 am Post Subject: 3 ceiling lights not working |
Help please! lights in the hallway working upstairs but not in the three bedrooms. All floor sockets work fine. I have a MK Sentry consumer unit. (no fuses in it) Have obviously checked that the switch for upstairs lights is up, which it is. Checked all ceiling light fittings and found that one had a dodgy light bulb fitting. The bulb wasn\\\'t catching properly and was at an angle. Could this be causing a short circuit, which could have blown all three lights? What should I do? |
Qedelec
Joined: 22 Jun 2005 Posts: 1141 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Tue Jan 31, 2006 12:33 pm Post Subject: |
Unlikely to have 'blown' the lights if all the breakers are made.
More likely you have lost the feed from a light to the next in the chain.
If you are confident using a multimeter, you could check at the fittings but if not call a local electrician. __________________ "Shock me again and I'm gonna turn you off"
Life's a beach. |
jockie
Posted: Tue Jan 31, 2006 12:47 pm Post Subject: |
Thanks. Think I might need to call someone in. No idea how to use a multimeter.
Cheers, Jockie |
