DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
faulty ceiling light
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
jockie
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 31, 2006 12:03 pm    Post Subject:
Reply with quote Thanks
All lights are out in first floor bedrooms. Have a Mk sentry consumer unit. Turned off mains, switch is up for \\\'upstairs lights\\\' still no lights. Checked all ceiling light fittings and found one bulb \\\'catch\\\' on the fitting -don\\\'t know correct word, sorry!- is slightly broken, leaving the bulb at a slight angle. Could this be the problem causing a short circuit? What do I do next?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Jan 31, 2006 9:27 pm    Post Subject:
I'm sorry you haven't had any earlier replies, have you solved it already?
edited to say, I'm not quite clear, did you mean that all the MCB's are in the "on" position?
For a start, trip the MCB for the upstairs lighting circuit off, take out the bulb that looks wrong. Then have a squint at the bulbholder with a torch; it might be that it is bent or cracked. they can go brittle with age and heat.
If it looks OK, try putting a new bulb in and see if it is held correctly, or if one of the bayonet sides is out of place (if it is make a note to buy a new one tomorrow.
then try turning the breaker back on at your consumer unit (fusebox).
If the MCB had tripped, It is quite likely that the MCB tripped due to a sudden surge when a bulb failed, this often happens and is nothing to worry about unless it happens often enough to annoy you.
If the glass of the bulb breaks and you can't get it out, some back and I'll tell you a trick to getting the broken part out without cutting yourself, using only ordinary kitchen things.
edited to say, looking at your other post, I was barking up the wrong tree. Pay no attention to me icon_redface.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Faulty ceiling spotlight 4 1920 Mon Jun 19, 2006 3:45 pm
Ceiling spotlight faulty but works when not in its housing 4 520 Sun Sep 17, 2006 9:16 am
Faulty fluorescent light 6 220 Tue Feb 24, 2009 3:57 pm
Faulty Bathroom Mirror Light 10 1720 Mon Nov 13, 2006 5:28 pm
Faulty Light Switch 5 140 Sat Sep 27, 2008 12:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
