DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Lead water tank removal
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jeebee
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 31, 2006 4:05 pm    Post Subject:
Reply with quote Thanks
Hello, I live in a victorian flat still equipped with its original lead-lined wood water tank. I wish to remove this and have a tankless all-mains-fed system (the reason for this is the tank is built into a separate enclosure within the height of the bathroom, so removing it will open up the room). I\\\'ve already converted all the cold water systems to run from the mains, however wanted some advice about the hot water feed. Currently the hot water cylinder is gravity fed from the tank, the hot water cylinder itself is an un-insulated cooper tank that appears to have been recently updated with a new emersion unit. I\\\'m quite happy with doing the pipework to make the hot water mains fed, but wondered if there are any issues involved with this that I haven\\\'t considered. The hot water pressure is currently pretty dismal, so I though of using a restrictor valve on the hot mains feed, so I can increase the pressure in the system without subjecting the system to full mains pressure. Anyone carried out this operation or know of any unexpected pitfalls that I may encounter?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisRoberts
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 31, 2006 5:47 pm    Post Subject:
I wouldn't. Unless a cylinder is designed for unvented use it's gotta be dangerous to do what your talking of. U have to have been on an unvented course, presumably to avoid people doing what you're proposing. icon_rolleyes.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Tue Jan 31, 2006 5:56 pm    Post Subject:
Quote:
unexpected pitfalls
No ifs, no buts, it would burst.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Tue Jan 31, 2006 7:20 pm    Post Subject:
Burst would be an understatment
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Water Tank Removal From Loft! 8 260 Tue Feb 17, 2009 9:47 pm
Storage tank removal 4 220 Sun Apr 06, 2008 8:02 pm
Removal of Aga water boiler 9 1980 Tue Jun 27, 2006 4:15 pm
Plumbers mate putty removal ? 4 340 Thu May 08, 2008 8:52 pm
Bath overflow fitting removal 6 140 Mon May 26, 2008 2:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
