WKD
Joined: 01 Feb 2006 Posts: 1 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Wed Feb 01, 2006 8:30 pm Post Subject: EXTENT A WIRE TO GARDAN |
.1
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Wed Feb 01, 2006 9:47 pm Post Subject: |
your plans are as clear as mud. By the sound of it, you haven't a clue what your power requirements are and you dont know a right lot about circuit design either . . .
for starters, 6mm˛ will have trouble fitting into a socket, never mind a light. And outdoor cable runs must be protected, normally by running armoured cable and terminating in appropriate glands.
do you know about part p? http://www.diynot.com/forums/viewtopic.php?p=245116#245116 (see ban-all-shed's long post)
your electrician will better advise on circuit design.
"I wanna PUT" >> "I want to put" or "I would like to put"
txt tlk confuses ppl on ere, esp. when u r trynna tell us impt detls bout ure install. AND SHOUTING IS RUDE. |
rhino36
Joined: 01 Feb 2006 Posts: 25 Location: Bournemouth, United Kingdom Thanked: 0 times
Posted: Wed Feb 01, 2006 10:44 pm Post Subject: Crafty spot on |
Lynda, Crafty is totally correct, the wiring has to be mechanically protected and the circuit must be protected by an RCD. Unless you are competent in electrical installing it`s best to get a professional in. |
moderator
Joined: 27 Jun 2004 Posts: 316 Location: United Kingdom Thanked: 0 times
rhino36
Posted: Wed Feb 01, 2006 11:02 pm Post Subject: Apology |
Sorry Lynda, new on the site (if you had bothered to check), only trying to be helpful.
________________________
lynda, moderator
I realise that, i too am being helpful, just pointing out your "error" |
