DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Baumatic BDW13 Overfilled "E4" Error
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
thankyou
from United Kingdom
PostPosted: Fri Feb 03, 2006 8:37 am Reply with quote
Hello, can anyone help with this. I have a relatively new Baumatic BDW13 dishwasher that has stopped working properly and just gives the error message "E4". The user manual says the cause of it is:
Too much inlet water.
*NOTE * - THERE ARE
NUMEROUS CAUSES OF AN E4
MESSAGE. REFER TO
APPLIANCE USAGE SECTION
OF THIS MANUAL FOR
GUIDELINES ON HOW TO
PREVENT AN OVERFILL.
and the solution is just:
Overdosing. 3-in-1 put in
with salt and/or rinse aid in
the appliance =overdose.
Could also be a Water
Pressure problem.
The water pressure certainly isn't much above or below what it normally is , but my wife did put some soda crystals in with the dishwasher tablet, and so she may have overfilled it. There's no water standing in the bottom of the dishwasher or anything, but I can't seem to get the E4 error to go away. Can anyone help, please. Many thanks.
Back to top
 Alert Moderators
thankyou
from United Kingdom
PostPosted: Fri Feb 03, 2006 9:52 am Reply with quote
Not to worry - I turned it on it's side for a few minutes, and after a lot of water drained out it works fine.
Back to top
 Alert Moderators
tiredengineer
from United Kingdom
Thanked: 6 times
PostPosted: Sat Feb 04, 2006 12:18 am Reply with quote
Foamed up and flooded the base. (Under the cavity). If you get the E4 again I'd suggest tipping it backwards about 45 degrees to drain the base. Lying it on it's side can upset the water management system.
If you're using 3 in 1 tablets do not put rinse aid into the machine as this can cause overfoaming. Don't put soda crystals, bleach or washing up liquid in it as this also causes overfoaming.
Unplug your appliance before working on it.
Back to top
 Alert Moderators
olddon
from United Kingdom
PostPosted: Sun Sep 10, 2006 8:36 am Reply with quote
I have a mouldy smelley w/s and have tried flushing without success
[10]times using..90d wash ,soapey wash,hot & cold wash with,soada,etc ,
ive not tried bleach yet,im going to try bleach next,then if no success ,ill
try lemon juice,then ill try fitting another trapp,
watch this space!! for my results
old don.
ferther to this above done all of the above and a very emty hot wash seems to have cured smell,march 2008
dw
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
kenmore washer overfilled by teenager, won\\\'t spin. 3 2960 Tue May 17, 2005 2:32 am
Baumatic BDW13 Dishwasher 3 4300 Mon Oct 23, 2006 8:46 pm
Baumatic bdw13 water not draining 4 320 Mon Feb 28, 2011 5:23 pm
Baumatic BDW13 dishwasher problem 3 320 Sun Apr 03, 2011 7:50 pm
beaumatic dishwasher bdw13 wont start cycle 11 1020 Sun Dec 20, 2009 5:47 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
