DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
help with rad valves
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
cactus
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 04, 2006 9:40 am    Post Subject:
Reply with quote Thanks
Hi, I need to temporarily remove a radiator in the bathroom. All the stuff I\\\'ve read online says there will be a manual control valve at one end, and a locksheild valve at the other, which i should be able to remove the plastic cover from. However, both valves look exactly the same, like temperature controls with a + and -, and i can\\\'t remove the plastic cover from either one... I\\\'ve compared to other radiators in the house, some of which do have removable plastic covers. what do i do if i can\\\'t remove the cover - just turn it clockwise to close it? icon_confused.gif please help! thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sat Feb 04, 2006 10:15 am    Post Subject:
With temp. controls+- -....no worries they`ve just got 2 wheelheads, the valves inside are identical.just shut them and count the number of turns just in case one has been used to balance flow
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Moving an upstairs Rad - no drain valves 2 300 Wed Mar 19, 2008 7:04 am
Boss White and Plumbers Mait: Rad valves 3 420 Thu Mar 20, 2008 10:02 am
old Drayton thermostatic valves 2 360 Fri Mar 14, 2008 4:41 pm
Looking for angled service valves 4 240 Thu Mar 13, 2008 1:22 pm
Are cheap diverter/thermostatic valves a bad idea? 4 420 Tue Mar 11, 2008 1:34 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
