DIYnot
Local | Network
   DIYnot > Forums
Local | Network
oil stains on carpet!!!
This topic originated from the How to page called Oil Paint
Click here to return to the page called Oil Paint.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
clumsymumsy
from United Kingdom
PostPosted: Sun Feb 05, 2006 2:48 pm Reply with quote
Desperate tenant, needing advice on the removal of four week old oil paint spots on carpet. Each spot around a cetimeter in diameter. Tried spirits, scourers, hot soapy water, and various hand cleansers, and all to no avail. Landlord coming to veiw work imminently, and the wife is panicking!!! heeeeeeeeeeeeeeeeeeeeeeelllpppp!
Back to top
 Alert Moderators
mlb3c
from United States of America
PostPosted: Sun Feb 05, 2006 9:04 pm Reply with quote
this has worked for me. If you have a shop vac ready, it takes just a few minutes, but this is an important tool to have. Spray a mixture (50/50) water and ammonia with just a few drops of dish soap--spray on spot, let set about 1 minute, then suck it up with vac. If it doesn't work thoroughly the first time, repeat. should help.
Back to top
 Alert Moderators
Gary_M
from United Kingdom
PostPosted: Sun Feb 05, 2006 10:27 pm Reply with quote
I had success in the past with the 'brown paper bag and iron' method.
I am not sure how well it will work with oil that has been there for 4 weeks, but it might be worth a try :-
1. Put the brown bag over the stain, with the 'dull' side facing down.
2. 'Dab' a hot iron on top of the bag - don't let any part of the hot iron touch your carpet. Continue this for as long as necessary (putting a clean part of the bag over the stain once it starts to 'soak up' the oil).
3. Remove the remainder of the stain with some carpet cleaner.
Gary
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 6 times
PostPosted: Mon Feb 06, 2006 1:36 am Reply with quote
If it were me, I would probably try applying paint stripper to an inconspicuous area of the carpet to see if it harms the plastic fibers the carpet is made from. Hopefully it won't.
Then, put paint stripper on the spots and cover with something like wax paper to prevent the paint stripper from drying out.
Once the paint is softened, then apply white spirits (also called "paint thinner") and press the end of a wet/dry shop style vaccuum cleaner directly over the spot to suck the loosened paint and white spirits into the vaccuum.
Repeat as necessary.
White spirits will evaporate completely without leaving a residue.
The active ingredient in paint stripper is methylene chloride, and it will evaporate completely without leaving a residue either. There may be some gelling agents in the paint stripper that you might need to clean up with white spirits or water, tho.
Back to top
 Alert Moderators
Brightness
from United Kingdom
PostPosted: Sat Feb 11, 2006 7:19 pm Reply with quote
Talcum powder is also really good at removing oil spots. Put a good dollop of it over the stain. Rub it in with your fingers and leave for about 10 minutes vacuum up and if still there, repeat.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Stains on hammock..black mould? 2 760 Tue Oct 23, 2007 9:06 am
Linseed oil stains on laminate flooring. 2 500 Sun May 04, 2008 8:15 pm
throw up stains. PLEASE HELP 2 2420 Mon Jun 18, 2007 7:35 pm
under arm stains 3 6500 Tue Jul 11, 2006 9:14 pm
STAINS FROM CAT 4 2020 Sun May 21, 2006 6:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
