DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Light flicker
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
festa
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 9:13 pm    Post Subject:
Light flicker
Reply with quote Thanks
When i switched my kettle on today the ceiling lights flickered! icon_cry.gif Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 9:47 pm    Post Subject:
high power demand. wouldnt worry too much
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Feb 06, 2006 9:50 pm    Post Subject:
Mmmm...
The switching on of a 3kW (absolute max) load should not make lights flicker.
Festa - has this happened before? Has anything changed recently? Does it happen wherever you plug in the kettle? Do other appliances cause the same effect?
Back to top
 Alert Moderators
colport27
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 9:54 pm    Post Subject:
Our hoover does this in our house?
Should I be worried?
I know I will call the sparky back that fitted the new DB.
Damn, that was me.....!!!!!!!!!!!
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 10:11 pm    Post Subject:
hoovers are a totally different type of load. kettles etc are resistive
Back to top
 Alert Moderators
colport27
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 10:13 pm    Post Subject:
Well our lights still flicker when the hoover is switched on.
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 10:15 pm    Post Subject:
most high loads do. lights in my house dim (very slightly) when the shower is switched on
Back to top
 Alert Moderators
colport27
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 06, 2006 10:21 pm    Post Subject:
So in answer to festa`s original question what`s the reply?
Loose neutral connection at the DB?
Back to top
 Alert Moderators
festa
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 07, 2006 6:43 pm    Post Subject:
Cheers for the reply, today i lifted a few boards to check the junction boxes of the light circuit for loose connections in any and found a loose N wire to one of my spot lights in the kitchen......tightened it up and the flicker has now stopped.......strange but true hmmmmm icon_biggrin.gif Big thanks !!!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Upstairs light flicker 12 640 Sat Aug 14, 2004 2:01 pm
Outside PiR unit causing other light to flicker 10 680 Tue Dec 14, 2004 1:06 pm
What would make a light flicker when using dimmer switch? 11 2860 Sat Mar 24, 2007 1:25 pm
Lights flicker, go off, come back on 2 200 Wed Nov 19, 2008 9:12 pm
Flicker on lighting circuit 8 280 Fri Jun 05, 2009 7:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
