i have a sime friendly combi boiler and i keep getting 2 problems with it.
1. the pilot light will go out every now and then, sometimes once a week sometimes two or more times a day, what could this be?
2. If i turn the hw upto full temp on the dial the water will run hot , in shower/bath, then run cool for a while. i turned up the incoming water flow to try to stop it overheating and cutting out while running full temp but the boiler cannot heat the water quick enough. im left with turning the temp down to about 3/4 full and slower incoming water. this stops the boiler from over heating then restarting again but dosnt give really hot water, what could be the problem?
sorry for long questions, any help gratefully recieved
nearly forgot, i also have 1 nearly cold radiator in my back bedroom. the bathroom fills up first then the back room then the 2 front bedrooms. the front 2 and bathroom rads are very hot but the bb rad dosent warm up. ive bled the air out and the valves are turned to hot. ive tried turning the bathroom rad down to put the water into the bb rad but still no better, any thing else to try?
