DIYnot
Local | Network
   DIYnot > Forums
Local | Network
2 way 2 gang dimmer switch problems!
Author Message
ajstant
from United Kingdom
PostPosted: Wed Nov 12, 2003 10:37 am Reply with quote
Hi
I have a problem with my two way s gang dimmer switches for the hall and landing lights. I used to have normal on/off switches downstairs and up, this seemed to work fine.
When I replaced them with two two-way dimmers things started to go wrong.
Downstairs I have 3 wires: red, yellow (with red band) and blue. For the same light but on the upstairs switch I have 5 wires: red (x2), black (with red band), yellow and blue. I have identified what I think is the constant live at both ends.
The best I can get is a low glow on the upstairs light, no dimming and no control whatsoever from the downstairs switch!
Can anybody please help me with this?
Thanks very much,
Andy
Back to top
 Alert Moderators
il78
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 12, 2003 11:01 am Reply with quote
I take it that the hallway light is working fine on the dimmer……
At the hallway switch:
3 Core cable RED/YELLOW/BLUE
YELLOW to C
RED to L1
BLUE to L2
At landing switch:
3 Core cable and 2 Core cable RED/YELLOW/BLUE & RED/BLACK
YELLOW to C
RED & RED to L1
BLUE & BLACK to L2
All earths to brass terminals
I have been informed that 2 dimmers in circuit will not operate, so you must have a normal switch installed somewhere (ie, upstairs)
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1924 times
PostPosted: Wed Nov 12, 2003 11:24 am Reply with quote
I take it you have bought proper multi-way dimmers, with a master/slave relationship, or some sort of intelligent control link between them?
Not just dimmers that have 2-way switching capability so that you can have ONE dimmer in place of ONE 2-way switch?
If not, you're *****d, as you can't have 2 conventional dimmers in series.
Back to top
 Alert Moderators
ajstant
from United Kingdom
PostPosted: Wed Nov 12, 2003 1:53 pm Reply with quote
Both dimmers (upstairs and downstairs) are 2 gang 2 way switches. To be honest I didn't know they wouldn't be 'professional'.
This means I can't do what I want then I presume? icon_sad.gif What will happen, nothing or something? icon_question.gif
Why won't two dimmers work in series then?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1924 times
PostPosted: Wed Nov 12, 2003 3:22 pm Reply with quote
It's nothing to do with them being professional - they could be the finest product in the world, but they still wouldn't be able to do what they weren't designed to do. Did they come with a wiring diagram which led you to believe that you could have two in the same circuit?
What will happen is what's happening now.
Because even if they were simple potentiometers their resistance values would add up, making the final voltage output very low. As they aren't but are semiconductor switching circuits then what will almost certainly happen is that the output from the first dimmer will not be enough to trigger any functionality in the second.
But even if they were simple pots, nobody with even a modicum of knowledge of how two way lighting circuits work (i.e. which wires carry current and when, depending on relative switch positions), or of what voltage, current and resistance are would ever expect to be able to put 2 dimmers in series.
Are you sure you are up to this?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Wed Nov 12, 2003 6:36 pm Reply with quote
i think itt is a case of he didn't know you cant have two ordainairy dimmers controling the same circuit. after all it doesnt say on the box, that no one reads that you can't
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1924 times
PostPosted: Wed Nov 12, 2003 10:58 pm Reply with quote
Ah - maybe it's just me, but even if you don't know how they work, (and I don't, precisely), surely it must be obvious that what you have is a little box where you put 240V in at one end and get less than that out at the other end, which is why your light is less bright. And that if you then take that "less than", and feed it INTO another one of the magic boxes, you'll get so little out that the light won't work at all?
But apparently not.
I've never fancied a dimmer at one end of a two-way switch circuit, as I just know that I'd always be at the wrong end when I wanted to adjust the wick, so I've never looked at "2-way" dimmers - do they really not have a diagram showing 1 dimmer and 1 switch?
Back to top
 Alert Moderators
Scoby_Beasley
from United Kingdom
Thanked: 50 times
PostPosted: Wed Nov 12, 2003 11:23 pm Reply with quote
Totally agree
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Problems connecting a 2 gang dimmer 2 640 Tue Jul 03, 2007 11:38 am
triple gang 2 way switch problems 3 380 Sat Jul 05, 2008 11:34 am
2 Gang 2 Way Light Switch Problems 10 140 Sun Apr 27, 2014 4:31 pm
two gang switch problems 9 420 Mon Aug 11, 2008 6:52 pm
2 gang switch problems 6 640 Thu Apr 08, 2004 1:36 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
